Spots only show up when camera is aimed at blue sky
SOURCE: spots on images
spot is dust on the sensor. unfortunately, you will have to clean your sensor by yourself (it cost 30$ in a shop) There a fonction in the menu that up the mirror so you can access the sensor. very carefull. the pixel are so small that you can not see the dust but they are there!. caution, you need to put your body on a pod, have a good light to see what you make and some adapted items to clean the sensor. If not neede, avoid liquids. good luck and don't panic.
The 28-135 zoom lens has at some point had moisture inside it. These spots that you can see are dried water marks.
You have to take the lens apart and clean the lens with a class cloth.
Alternatively you can take the lens to a specialist service center to be professionally cleaned.
Regards.
SOURCE: Smudge-like spots in picture of new SX20
I had the same problem with mine two i ended up sending it to canon and they replace the lens unit.
SOURCE: My camera is producing spots, or freckle-like or
You have dust on your sensor. your best bet is to get it cleaned professionally, . if you want to clean it yourself, get a kit like this
http://www.amazon.com/Digital-Survival-KIT-Sensor-Eclipse/dp/B000PNGM18/ref=sr_1_2?s=electronics&ie=UTF8&qid=1299393725&sr=1-2
good luck
