Fills with water but it won't agitate or spin
What is the model number?
model # 417.44092500. The belt looks ok. I tried to unplug it to reset the computer.It worked ok for a week after that.Started doing it again, tried to unplug it again but nothing this time.Now during the drain & spin cycle , it gets hung up at the last minute of the cycle. I have to cancel it .
You will need to replace the control board. Here is a link to the part you need. http://click.linksynergy.com/fs-bin/clic...
Hi Richard,
You hit it right on the head. Washer is working fine. Thanks for the help !
Glad I could help!
The washer is starting to do the same thing again
SOURCE: Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
SOURCE: Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
SOURCE: Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
SOURCE: Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
