SOURCE: LG 37LC7D remote doesn't work
I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
SOURCE: i have a lg 37lc7d will shut its self off
When it shuts off does the power light stay on like the unit is still on?If yes,try shining a bright flashlight at the screen and see if you can see any video.If you can your power and main boards are ok.you would then probably need an inverter board or panel.If it is shutting completely off you need a main total assembly since you have already replaced the power supply.The main total assembly is avery common issue on lg lcd tv's.
SOURCE: how do i remove base stand on an lg 50pc65 tv to
you have 3 philips head screws in the base, unscrew this and wil be abel to get it wall mounted after that.
SOURCE: LG 37LC7D 37-inch 720p LCD HDTV
Unplug it for about an hour to let it reset itself and try again, if it still has problem then you will have to open it up or take it to the repair shop. The power supply module will have to be looked at first to make sure all the voltages are present. Right now the 5vdc standby power supply is working and may be partially function processor.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
