Compact Frigidaire 2.5 cu ft
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
SOURCE: FREEZER NOT DEFROSTING AND ICING UP
Fridgedaire has a lot of defrost termination switches that are separating and not allowing the defrost cycle to heat up. The defrost termination switch is located behind the wall that is icing up, take out the screws that hold the back wall in place and use a hiar dryer or hot water to remove ice do not use an ice pick or sharp object of any kind. the def terminatin sw is small and round about 3/4 of and inch thick and has two wires coming off of it one goes to the defrost heater the other usually back into the wiring harness. check it to make sure it is not coming apart. Ohm it and the heater out it should have continuity when below 20 degress. the heater should have continuity all the time,.
SOURCE: Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
SOURCE: my frigidaire refrigerator keeps defrosting on the freezer side
sounds like a bad defrost timer
or depending on the model a bad
electronic or adaptive defrost board
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Frigidaire 2.5 cu ft FFPH25M4LB
Check to see if the defrost timer is stuck. It is located by the compressor. Sometimes they get stuck during the cycle. Here is a diagram. The timer is number 28.http://cdn.appliancepartspros.com/images... You can use a flathead screwdriver to turn the timer. You will hear a click and the compressor will come on as long as there isn't another problem.
