Printronix P5010 Matrix Printer Logo
Posted on Jan 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
P5010 line printer, I want to print in condensed mode
In my Printronix printer P5010, two config settings have been saved , one is for printing in 'condensed' mode. Accdiently I hv changed the settings.
Now I want to take print-out in condensed mode, How to change / store my settings
Anonymous
Level 2:
Scholar:
  • Expert 51 Answers
  • Posted on Jan 01, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
51
Questions
0
Helped
22503
Points
115
This can be done by sending an "escape sequence" to the printer. Basically you create a text file using Notepad and then print it. Of course the magic escape codes to do this are found in your P5010 Owners / Users Manual. I don't have a copy at hand. If yours has been misplaced, you're pretty much out of luck. As a long shot you can try the standard Epson codes for condensed print.
IBM Proprinter driver 64 bit
There is no proprinter Driver for 64bit. You can use the Epson emulation or the P7000 driver with the printer in its native emulation.
2answers
Driver for xp
Hi
This unit is no longer supported.
Driver download
You can use the P7000 Driver from the manufactures website.
Printronix 5 series printer driver
Have you done an online search for the drivers you are looking for? Usually if you do that you will find the web site that contains the drivers you need to download to get the printer to work.
I am getting a constant Ribbon stall on one of our p5010, we have totally cleaned hammer bank areas and put in new gold ribbons, we compare ribbon drag on the stalled p5010 to our many working p5010 and...
there are few things.. may be your ribbon hub damage... your ribbon motor not working properly.. check ribbon motor connection...and finaly L/C..CMX..CFX board.
Printronix p5010 with AS/400 IBM server
I can get the P5010 printing on your AS400... But, there are to many things to check without knowing a little more about your environment.
If you can't ping the PTX P5010 from the AS400 or a PC, then you have a printer configuration problem.
Take the printer offline and hit the Print Config button. and then the enter on OPs Panel. Then post top or first paragraph of the config. so I can look at...
__________________________________________________________
If you can ping the printer from the AS400...
You will need to create a remote out que on AS400... command is crtoutq then hit F4...
if you can't post the printer config here... Fax it 972-233-7306, Attn: P5010, Toby
Top Printronix Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
