I had same problem, and fixed it just as per URL link from Wizz.
Apart from following the Sony methodology by the letter:- a couple of things to note:-
1) Make sure you appreciate the difference between a data disk and a burn image. To copy the ISO file you need an image copy of the file, the disk will also need to be "fixated", this is a normal function of most disk burning software but may be prompted as a tick list before you burn the image.
I downloaded burn epress from
http://www.nch.com.au/burn/plus.html and it worked fine
2) I got a "No DWLD 09" error after I had put the disk into the player. I tried it several times but still got the error. I solved it by changing CDR disk manufacturer. I was using Maxwell CDR-80's and when I changed to a JVC it worked fine.
I bought Lost Season 4 DVD set & all of the previews will play, but the episodes won't play.
I have the same problem but it only happens on certain BR Discs. I can't figure it out and Sony's site has nothing on it.
I have then same problem with movie Traitor - tried two different disks....trailers play...move does not load.
I have the same prome with some movies specially those who have u control like the new blu rays from Universal
i bough Baby Mama and Mamma Mia and i can't played on my bd s300
I have the same problem, I have noticed it is only when i play blu-rays with DTS sound (like mama mia) any solutions?
