I can log on to Windows using a limited user account which was already in the computer and required no password. Simply click on that limited users name/icon , no problem. However Administrator Account while showing Administrator user name/icon, requires Administrator Password. Bought DeskTop at yard sale and dont know Administrator password. Therefor I cant delete or download many programs or change many settings without that password. What to do?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode Enable Boot Logging Start Windows Normally Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator it will prompt you to enter the new password enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Safe Mode with Networking
Safe Mode with Command Prompt
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
hope this helps
SOURCE: log on ton windows (user name owner. password) never set passwor
if u did not set any password just leave it blank then you can log in to your account
SOURCE: I was given a compaq computer running Windows XP.
I would suggest you to try the following :
Boot the computer in safe mode.
Press F8 while booting the system, It will give you Windows Advance boot option, Select Safe mode and press Enter. You will see two accounts, Administrator and the Previous User's . Select the Administrator. If it allows you to log in, go to control Panel, User Accounts and delete the previous user's account and create a New user with your name. Reboot the computer in normal mode.
Hope this works. Please let me know if you need further Assistance. Your comments and ratings are highly appreciated.
Thank you for choosing Fixya
SOURCE: My user account disappeared...help please
you need to log onto the old account, to see your settings. that happens when you have two accounts.
SOURCE: Missing Administrator Password
there are many great software programs ,i've used them and they work .just google "windows reset password software".some are free .some of them require you burn a boot disc on a different pc,obviously.insert cd into the pc your locked out of and follow the instructions.you can reset,delete ,disable and then your good to go!!!your pc will be accessible and all files and settings will be entact!!!
your PC might still have a virus, you have to download or install new virus protection program to solve this and virus program should be always be updated, try avira premium security 90 days trial, this one work for me than avg.
mhel
[email protected]
Here is a
simple way to access Windows XP with Administrator rights and privileges if you
have password protected your User account on your Windows XP system and can't
remember the password(s) to login. Whenever Windows XP is installed on a
system, it creates a default account called "Administrator" and by
default this account is not password protected. Therefore, if you bought a
brand name computer (such as Dell, HP, Compaq or Sony)or you have installed
Windows XP yourself. You should be able to login to the computer through the
unprotected.
You can log on as an administrator to assign a
new password to your account. To do this, try Method 1.
Method
1:
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button
after you switch on until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Click through several self-explanatory
screens until your reach the familiar 'Welcome' screen.
Note that
this welcome screen is limited to 256 colors and 640x480 resolution because the
primary graphics will have been set to the Windows Safe Mode software VGA
adapter. You will not be able to change this mode even in Display options,
while Windows is running in Safe Mode.
Find
the icon for the Administrator user. If the default settings of your system haven't
been changed, there should be no password for this account.
Continue on to the User Settings control panel. Here you can change any
of the other passwords for user on the machine. Make any changes you want.
Reboot your computer. As long as you don't
press any keys (e.g. F8) during the boot-up the
computer will startup normally.
Here is a
Windows XP yourself. You should be able to login to the computer through theunprotected
Administrator account.
Method
1:
Note that
Find
haven't been changed, there should be no password for this account.
Continue on
to the User Settings control panel. Here you can change any of the other
Reboot your
computer. As
long as you don't press any keys (e.g. F8) during the boot-up the computer will
startup normally.
Login With the Administrator Account in Windows XP Professional
Click
the "Start" menu and then click "Log Off."
Click
"Switch User" when the prompt screen opens.
Press
"Ctrl," "Alt" and "Delete."
Click
on "Administrator" when the "Log on to Windows" screen pops
up. Type in the administrator password, if applicable.
Click
"OK." You will now be logged in as the administrator.
Log On as An Administrator in Windows Vista
Start your computer and
allow it to continue through its startup process. By default your computer will
simply load directly to the primary user account (usually the administrator
account), but if there are multiple users on the system it will load to the
account login screen. Use the mouse to
click on the administrator account from the list of available accounts to log
on. This step is only necessary if you've customized Windows Vista with more
than one account or you have set the operating system to load the login screen
first. Enter the password
required in the password field to log on to the administrator account. Click the
"OK" or "Log On" button once you have entered the password.
This button may be labeled differently depending on the version of Windows Vista
or any GUI (graphical user interface) changes you may have made.
Log on as an administrator from within the Windows
Vista environment by clicking on "Start" and then "Log
Off." As soon as you have logged off, you will be returned to the login
screen where you can choose the administrator account from the available list.
If this answer helpful please vote me. Good luck. Thanks for using FixYa
The problem is not with adminstrator on the computer by only with the setup2.exe. It states it requires adminstrator to delete but will not accept that I am.
Which operating system ? Your first post stated you could not log on as asministrator because you did not know the administrator password and what is this setup2.exe right click on this setup2.exe select properties then security tab make sure you have full control there should be an option to add or edit depending on your operating system let me know how you go
