My no is 0172330048..can u help me ???
PUK Code
PUK stands for Personal Unblocking Key. This is a unique eight-digit code specific to your SIM card. This is required when the PIN number to unlock your mobile phone is entered incorrectly 3 times. You are then given 10 attempts to enter your PUK code. If an incorrect PUK code is entered after the 10th attempt, you will block your SIM card permanently and will require a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack. If you do not have this then - Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give them your account details and they have confirmed your identity. For details to obtain the PUK code for the SIM card, please click on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
SOURCE: pin 2 blocked samsung d900i.
i've had this before i went on the net got the unlock code sent through try this if you haven't already. hope this helps
SOURCE: i put in my puk code and it block my sim card so i
Only the sim is blocked, not the phone. The unblocking code is located on the sim casing when you bought it. It will ask you to enter the code and new PIN code 2 times but will completely block it if the limited number of attempts is reached. You can just simply replace the sim and the phone will work again normally.
SOURCE: It says PUK Blocked on
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
But Please careful
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code. It can be as many as 8 digits,
and it is random. If you enter too many wrong codes, you can permanently damage the device.
So Please You Go to Service office and Get the Duplicate Sim From Office Oprater
Same Your No Problem will Solved
Hi
Thank You.
