Showing error code E4H
Hi - Are you certain the error code is E4H? This manufacturer does not have such an existing error code however Frigidaire does have an error code E4A. Typically it indicates a faulty issue with the timeout program. Contact a professional to move forward accurately. Technician will check for anything that would cause extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally after it has be diagnose and code returns, the main control will possibly need replacing.
Hello - Are you certain the error code is E4H? This manufacturer does not have any E4H error code for any washer or other units. They do have E4A and E5A codes however.
