Does the battery gradually lost its power, and do I have to buy a new battery. Otherwise the camera is working perfectly. Great camera for the price.
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
SOURCE: The camera doesn't turn on,
I am sorry to hear regarding the trouble. As you have already used new batteries and eliminated battery as one of the causes,there are a couple of other reasons mentioned below :-
1. Battery connectors are at fault. Take a cleaning solution and cotton. Rub it against the battery connectors to remove any possible dust, dirt or rust.
2. This could be an issue with internal circuitry such as faulty PCB board located above the mainboard. In these situations, repair is the only resort.
Try to use a USB cable and connect it to PC. If that still does not work, i would advise you to send it to the seller or any of the distributors to get it replaced / repaired without any cost as it is new..
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Thanks for your very comprehensive reply.
