Stihl Fs36 Line Trimmer Gas Tank Logo
Lee Miller Posted on Oct 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to see a fuel line diagram for Stihl fs36 trimmer
Curtis Sewell
Level 3:
  • Stihl Master 7,482 Answers
  • Posted on Oct 19, 2012
Curtis Sewell
Stihl Master
Level 3:
Answers
7482
Questions
Helped
1942431
Points
24946
Hi Lee Milleer
I hope this is what your looking for
Please take time to rate me
Bud
I need to see a fuel line diagram for Stihl fs36 t - 10_19_2012_1_55_26_pm.gif
Stihl fs38 line trimmer fuel line diagram
Easy way to figure it out without a diagram. Connect the filtered fuel line from the tank to either port of the carburetor. Leave other carb port open. Press purge bulb several times. If the filtered line is connected to the correct carb port, fuel will spurt out the open carb port. No fuel, switch filtered line to the other carb port and repeat purge to verify correct connection.
Warning, NEVER use the unfiltered fuel line for this procedure.
Need fuel line routing for stihl fs36 trimmer
the line with the in-tank filter attached goes to the inlet side of the primer bulb
the action is from the tank through the pump into the needle area out to the primer back to the tank
My fs36 Stihl bulb won't pump up, or start. I have to feed gas into the air cleaner to keep running.
Your carburetor is clogged, probably due to using old fuel or allowing it to sit unused for several weeks. This is a common problem with small engines when using gas with an ethanol additive. You will have to rebuild or replace the carburetor. Given the hassle of finding the precise rebuild kit, getting all of the tiny orifices clear, the cost of the kit and carburetor cleaner, I recommend simply replacing the carburetor for about $50.
Always use a fuel stabilizer or ethanol free gas with small engines. For long term storage, empty the gas tank and run all of the fuel out of the carburetor.
Where do I attach the stop switch wire on a Stihl FS36 weed trimmer?
one end goes to the switch the other end goes to the ignition module
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
4helpful
Need a diagram for fuel line placement on Stihl FS36 line trimmer
Hi Lee Miller
Hope this is what you need
Bud
2helpful
What is the airgap for the magneto on a stihl fs36
normally .16 or a match book cover between the two would work.
Mar 27, 2010 • Garden
My stihl fs36 Whippersnipper continues to flood what is the cause
needs a carb kit with needle valve $20 at a small engine store
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
