ASUS Eee PC 1005HAB Netbook - Intel Atom N270 1.6GHz / 10.1" WXGA / 1GB DDR2 / 160GB HD / Webcam / W... (884116027775) Logo
Posted on Oct 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset to factory - ASUS Eee PC 1005HAB Netbook - Intel Atom N270 1.6GHz / 10.1" WXGA / 1GB DDR2 / 160GB HD / Webcam / W... (884116027775)
shahram
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 21, 2015
shahram
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
676
Points
6
Hello how can i reset to factory my eee pc 1015b bios password
Anonymous
Level 3:
  • ASUS Master 32,281 Answers
  • Posted on Oct 19, 2012
Anonymous
ASUS Master
Level 3:
Answers
32281
Questions
Helped
7905878
Points
102259
This WEB site gives instruction on - ASUS Notebook Restore to Factory Settings
http://en.kioskea.net/faq/4162-restore-an-asus-netbook-to-factory-settings
2answers
Factory reset my motorola xpr 7550
It is written in it`s mannual you can find it in attached link Motorola MOTOTRBO XPR 7550 User Manual or here is the video tutorial as well which is not for the same model but could may helps you
I have a Yamaha dtexpress. Very old, but works great. Except the snare sound. It is stuck on bongos. Is there a factory reset for the dtxpress?
It's possible to reset the DTXPRESS electronic drum kit to its factory default settings by performing a Factory Reset. Here's how you can do it:
Press and hold the [DRUM KIT] and [SAMPLE] buttons while turning on the power switch.
The display will show "FACTORY RESET OK?"
Press the [DRUM KIT] button to execute the factory reset.
The display will show "INITIALIZING" while the reset is being performed.
When the reset is complete, the display will show "COMPLETED".
Note: Performing a factory reset will delete all user kits, samples, and other custom settings that you have made. Be sure to save any custom kits or settings that you want to keep before performing the reset.
Factory resetting my Samsung Galaxy S7
hi Linda.
How to factory reset the Galaxy S7
  1. Swipe down from the top of the screen to pull down the Notification Shade.
  2. Tap the Settings button. It looks like a gear.
  3. Swipe up to scroll down on the settings screen.
  4. Tap Backup and reset.
  5. Tap Factory data reset. ...
  6. Tap RESET DEVICE.
  7. Tap ERASE EVERYTHING.
How to factory reset the Galaxy S7 ' Android Central
https://www.androidcentral.com/how-factory-reset-galaxy-s7
to read up more you could go to this link.
how to Factory resetting my Samsung Galaxy S7 Google Search
How do you factory reset this tablet?
    1)Go into your settings> Backup & Reset
    2)Tap the factory data reset option and to through the reset of the steps to confirm the factory reset
1helpful
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
1helpful
2answers
My nabi dreamtab wont reset why?
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabi™ Sync.
Netflix com
Performing a factory reset erases all of your settings and account information and restores your
1 Press home to go to the Home screen. 2 Highlight settings , and then press select to display the Settings screen.
3 Highlight factory reset, and then press select .
4 To continue with the reset, select factory reset. To cancel the reset, select back.
  • 5 When prompted, highlight yes to confirm that you want to reset your player, and then press
    select
How to factory reset d-link dir-825
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
