The cabrio has a shaft that runs between the wash plate and the rotor located under the washer. The usual cause for noise during spin is something that has made it's way between the spin basket and tub. But it's best to try and determine if the noise is from under the washer or inside the washer, that way you aren't randomly taking things apart. See if you can pin point the location of the noise.
SOURCE: Cabrio won't drain/spin, loud hum
Hello karlatw
Welcome
It sounds like the motor coupler is broken. Tilt the washer back &look on the floor for rubber or plastic shavings. This would indicatethat the motor coupler has failed. Another possibility would be thetransmission or drive block.
http://www.managemyhome.com/mmh/answers/Answers.action?intcmp=MMHxG_HomexAnswers_
Widget#l4q122032
Unfortunately you need service for this repair!
Please remember to leave a solved rating before you sign off!
Thank You
SOURCE: washer making a loud noise on spin cycle..cabrio
If you lift the outer cover you should see 4 supports at ech corner if one fell off it would spin un even and make a lot of noise
