Power is working to machine. Just replaced rotor but now machine will not power on.
We had the same problem (washer would not turn on). The problem was a small fuse blown in the power noise filter unit. The unit is a plastic block near the top of the washer on the inside - connected to the power cord. It is a very commonly produced unit and goes in a number appliances. The fuse inside fails frequently (so I hear) and is extremely difficult to replace due to the protective-covering material so it's easier to just replace the whole unit. I purchased a replacement unit for about $30.
Very easy fix:
1. Unplug the washing machine.
2. Take off the top of the washing machine (two screws in the back)
3. Identify the noise filter unit (top of washing machine, hanging on the right with the power cord attached to it).
4. Remove with one screw and unplug the two cables going into the noise filter unit. Slide out the unit.
5. Put in new unit. Screw it in, and plug the two cables into it.
6. Put the top of the washing machine back on (not necessary to test if the new unit works)
7. Plug in washer and run.
https://www.encompassparts.com/item/7814463/LG_Electronics/6201EC1006L/Filter_Assembly
http://www.amazon.com/LGE-ZENITH-FILTER-ASSEMBLY-6201EC1006L/dp/B006E7V7DW
SOURCE: lg front load washer model wm2077cw
I had the same problem and all I did was drain the water from the front, clean the filter, and it worked.
SOURCE: my LG WM2301HW is not
the inlet valve is mechanically jammed shut so when the controls tell it to let water in it cant because the valve is jammed shut.need a new valve.
SOURCE: LG WASHER WON'T Power on
Hello. If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
SOURCE: I have an LG WM0642HW washer. After a wash cycle
sounds like a loose connection either going to the main control board or a break in your power cord or the main harness has a fault in one of the connection locations to the main control the control is located under the upper control area this is also the schematic for your machine showing how to access the control area http://c.searspartsdirect.com/lis_png/PLDM/K0810327-00001.png this repair will require you to break out the multimeter if you are unable to visually see any misconnection I await your reply for any further questions Thanks Rick
p.s there is also a relay located on the power board and if you dont find any issue with the wiring it may just be the relay that is hooked on to the main control board as well. I await your reply
SOURCE: Hi, I can't open the
I am unable to find that model number for your unit but I did find another that was close and is also an LG Tromm click this link http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28702783&pkw_=basket&model_id=5520802&NewWindow=1 you would have to remove the bottom panel the one that has the drain filter attached to it by removeing the screws that hold the panel in place. Once the panel is removed then you would reach up along the side that the door lock assembly is on and you will see and feel a cord with a ring that you would pull and then your door would open once you pulled this cord. In some units if you unplug the machine for 7 minutes this also causes the control to reset and sometimes this also causes the door to be able to open once the control is reset. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
