I recieve the Low flow error code when the washer goes into rinse. Timer Stalls and if I smack the top of the washer get a brief fill of water then recieve the LF code. I have replaced the home water hoses and shutoffs and the problem is getting worse. Is this a mixer valve problem or electronic controll?
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
SOURCE: whirlpool/cabrio washer reads error LF and will not fill machine with water.
The serial number has a two letter designation, the first is where it was assembled and the second is the year. A long fill error can be several items, we all need to know first, how full with water, is your supply low on pressure or do you have a drain hose inserted far enough to cause a siphon condition? You should hear a gurgle splash as it drains.
SOURCE: Whirlpool model LSR7233EZO / doesn't fill fully
The fill switch is a very sensitive device. You can test it by blowing into the tube, listen for the switch to click, or use an ohms tester. They are actually adjustble, the adjuster screw usually has glyptol (thread lock) on it. I would replace one before trusting an adjusted one.
SOURCE: HF error code
hi,
check this-
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
good luck
SOURCE: whirlpool washer model lsr8233eq1
Hi gastang,
The problem is with your water valve. It needs to be replaced.
To access the washer follow these steps...
UNPLUG THE WASHER!
1.) Remove the 2 screws from either side of the control panel.
2.) Pull the control toward you a 1/4", then rotate it up and all the way over.
3.) Remove the white plastic wire connector to the top panel (it has 3 wires in it.).
4.) Remove the two clips on either side of the top panel. Do this with a screwdriver. Poke the screwdriver into the top panel to engage the clip, now rotate the screwdriver toward the rear panel.
5.) Lift the lid (for a hand hold) and rotate the entire cabinet forward to about a 45 degree angle then slide it toward you. Set it aside.
Here's a video that shows how it's done. But you'll notice that the screws on your control panel are in the front, the video has the screws in the back, but the rest is the same. Here's the video.
After you have access, you'll see the water valve on the right.
If this was helpful, would you take a moment and rate my solution? Thanks,
SG
SOURCE: Whirlpool Cabrio washer is leaking water
The problem
happens when your installer throws away the drain hose u-bend, and
stuffs the hose as far as it will go down the drain pipe. When this
happens the end of the hose can get pushed under water, which causes
the washer to siphon out the wash water when it fills. This results in
an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
