WHEN I TURN THE CAR ON, IT TAKES THE GPS ABOUT 20 MINUTES TO STAR WORKING, AND IT TELLS ME THE SATELLITE SIGNAL IS TOO WEEK, IF THE CAR IS INSIDE OR OUTSIDE, IF I LIVE IN THE USA, ETC, BUT IT WAS FINE BEFORE, PLEASE HELP ME THANK YOU SO MUCH [email protected] thank you guys God Bless you all, thanks
SOURCE: kenwood ddx-6019 password
try this code 5538 Use the am/fm to go up and down numbers and the scan forward to move over after you put the code in hold the scan forward button down it will either say approved or shut your radio off again. Hope it works for ya.
Contact Keenwood, they may make you send it in and charge a fee. Goodluck.
a friend of mine who is into bypassing stuff...found this method from sumwhere and it worked on my system...
u need to reset the system first by pressing the small button right next to <ATT> using a ball point pen or something pointed...
once it reboots,
keep the <SRC> button pressed till the display goes off, then while keeping the <SRC> button pressed, press the <ATT> button for 3 seconds, while keeping both of these pressed at the same time, press the small <RESET> button next to the <ATT> button using something sharp...
this hard resets the system and it reboots to a blank screen,
press the <SRC> button once and you have all the options working...
anything else, lemme know...
[email protected]
i think you find some softuare on ebay to unlock your radio....i m not 100% sure but you can take a locke
