The dehumidifier will not operate and shows a F2 error. It's manual says that is a sensor error but does not say which one
SOURCE: F2 ON THE DISPLAY / WILL NOT RUN / MODEL FDB30R1
hello sir/mam
this is because of the error in the programme so please switch OFF for 1 mint and switch ON then see the display.
SOURCE: My dehumidifier is giving me a F2 error message and isn't running
When I searched this error code, I found that F-2 means bad sensor. I found no further information as to what sensor it was. You don't give the name of the manufacturer, so I couldn't search from that perspective.
If it is a bad sensor, you may require professional repair.
Before I took it anywhere to be worked on, I would be certain that the catch bucket was setting square (indicating no water in the bucket).
Thanks for your interest in FixYa.com
SOURCE: Frigidaire Dehumidifier gives F2 error code and no longer runs.
ACCORDING TO FACTORY-NO SERVICABLE PARTS AVAILABLE
Good Morning Mark, thank you for your post!
I see that your Frigidaire dehumidifier is displaying an error code of "ES" and you would like to the meaning of that error code. The "ES" error code stands for evaporator thermistor error. This could be a possible problem with your control panel, thermistor, or a wiring harness. I would recommend contacting your manufacturer for further assistance with your dehumidifier. Best of luck! -Matt
