there is a momentary three way two pole rocker switch used to activate the linier motors that move the slide out. the most commin problem is they use a switch that dosen't have a high enough amp rating and the contacts burn out quickly. it is very importent to release the switch immediatly after the slide stops motion going in or out or these switches burn out very fast.
Earl: Changing the battery should not have caused the dimmer switch to stop working. First make sure you didn't accidentally readjust the dimmer switch. The dimmer switch could be bad or the low beam filaments in the headlight may have burned out.
Check the alternator. You can observe your interior dome light or the vehicle headlights as you rev the engine. If the light intensity changes with as the RPMs of the engine changes, then you have a faulty alternator.
This is your battery problem.
Just do the step below hope it will solve a bit.
get fully discharge and let automatically switched off. then connect to charging but do not switched it on after showing full charge, disconnect charging and switched your phone on.
initially do dis 4-5 time a week. After that do 1-2 a week.
This will increase your battery strength.......
Have you change the battery? Note: Matrix UPS need to be calibrate after changing batteries or reset the Smartcell communication board. to make sure that the UPS would detect that you already replace it with the new battery
i think its time to change your battery ,so try switching on the camera by changing the battery .if that not works then go for hard reset method,that is, remove the batteries and leave the camera for half an hour and then insert the battery and try
