Error Code
A error code F1-09 deals with the finisher of the copier. Have the bins gotten stuck or got something in it's way when moving up & down. I would turn the copier off and unplug the finisher from the copier, 1 screw holds connector in. Then I would turn it back ON and see if the code is gone, if so reconnect the finisher and you should be good to go...
F09 means overflow condition: unplug the unit. 1) check the drain hose make sure it's not plugged or kinked. 2) check the wire hareness connection to the drain pump, pressure switch and control unit
