Question about Hoover AAA140 Front Load Washer
Hoover washing machine model vhd-822 won't spin
Won't spin
6ya staff
SOURCE:
douglas smith
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
robert samples
  • 1314 Answers
SOURCE: HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Posted on Mar 23, 2008
danbhoy
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
Ian Greenland
  • 351 Answers
SOURCE: hoover washing machine 550mb keep
Hi are the clothes tangled up around the agitator if so the gearbox may be faulty or the brake may be worn,is it washing in both directions
Posted on Oct 09, 2008
Anonymous
  • 998 Answers
SOURCE: Hoover Washing machine wont spin
look at the belt and thumbs up
Posted on Aug 09, 2009
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
I have a Hoover Vision HD 9 kg washing machine, type VHD 916Z. I does not spin when there are clothes in the machine, it just starts the spin then "gives up" after 0.5 to 1 second. When there are no...
Double check the waste pump on the inbound side, which could be the cause of a wrong feedback to the pressure sensor switch. The filter can be clean, but the collector from the basket to the pump can be obstructed.
Jan 26, 2015 | Hoover Washing Machines
Hoover vision hd
the bearing are gone
Jan 18, 2014 | Washing Machines
Hoover vhd sensor dry 59 minute programme not working
"Rapid W&D 59 Min.
When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
If the other cycles work without issue, it in not faulty.
Check the wash weight.
Sep 20, 2017 | Hoover Washing Machines
I have HOOVER vhd 8143db80 when it went into its final spin, it started screaming. So I've taken the back off,I've noticed a lot of black carbon/metal dust on the pulley wheel. I've turned the...
That could be two things. Belts scream when they slip and are worn out. An bearings scream when they are dry or worn.
Your machine seems a bit obscure, as Google doesn't seem to know that model?
HOOVER vhd 8143db80 Google Search
VHD812
https://service.hoover.co.uk/manuals/VHD812.pdf
Feb 19, 2018 | Hoover Washing Machines
My Hoover VHD 1400 aaa has the front concrete weight off
This weight helps to balance the machine. needs to be put back on or replaced. Machine will not operate properly without it.
Mar 28, 2011 | Hoover Washing Machines
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Hoover visionHD vhd 842-80 will not complete its cycle (does not spin) lights flashing are 1200 &time saver button
Mine done the exact same thing and it was the bushes that went not the pump, so you can change them your self if you can
Nov 07, 2010 | Hoover Washing Machines
Hoover AAA140 Front Load Washer Logo
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
