LG WM-2277HW Front Load Washer Logo
Posted on Jan 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No water geting into washing machine.
I have a LG washing machine, model WM2277H. the water valve is on, the filters for both the hot and cold have been cleaned. don't know what else to do.
onthethejob1
Level 3:
  • Master 640 Answers
  • Posted on Jan 04, 2009
onthethejob1
Master
Level 3:
Answers
640
Questions
Helped
208761
Points
1483
Check hot and cold inlet vavle with meter...do you fell them humming,,or vibrating...
Model LG 2131SH is giving an IE code. Have replaced the Inlet Valve and still receiving the IE Error
Check water pressure. Check inlet filters--the ones inline at the back of the washer. Try a cold water only wash or try a hot/hot wash a see if you still get the error.
LG washer not filling with water
I take it you mean you cleaned out mesh inserts in the entry side of the hot and cold water valves?
Inside the valves are rubber diaphragms which when they age, perish......a bit like you and me!
Provided voltage is being applied to the valves you will hear them "Buzz" when the time is for water to enter the machine. If they buzz but do not allow water entry, they need to be replaced.
Poppa
http://www.cdbaby.com/cd/poppamadison
Lg washing machine model no. WF-7061DN. water is not going inside machine.water supply is ok & filter is also clear.
(this is pre-typed! Note last comment)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
My washer wm2277h does not have cold water just hot water..Can someone please help me
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
Common causes
door gasket damaged(torn)
Dispenser fault
Lint filter door not fully closed
It sounds like you might have a damaged outer bowl, broken by a foreign object(coin, wire,screw)
I want to clean the soap and softner holders I need a manual
http://www.retrevo.com/support/LG-WM2277H-Washers-manual/id/438ag213/t/2/
I clean mine with plain hot water and a rough towel. Then I fill the dispenser with hot water and run a light wash cycle.
2answers
Why the cold water keep coming even when the washing machine is of
the cold water is coming in the machine when the water is off is that what you said? shut off the faucets that go to the machine bad water valve its the piece that the hoses connect to please write back to clarify on when the cold water shuts off thanks again
Rick
I have the LG WM1832cw washer. Something is wrong with the cold water fill. Not the hot water just the cold water fill valve section as it fills VERY VERY SLOW (water trickels in). Hot water fills fast! I...
Is resistance between each terminal of INLET
VALVE ASSEMBLY 0.8~1.2 kω? If not replace it.
Is the inlet valve filter clogged?
Clean the filter.
Verify the voltage of the inlet valve connector is
120 V AC. No voltage? Check electrical connection.
Replace the MAIN PWB ASSEMBLY.
I have an LG training manual which might not be the exact one you need but it gives an idea what to look for.
LG WASHER REPAIR MANUAL
Post your model number at any of these
fine forums for an answer
that will save you big money::
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
NEW! http://sublimeforum.invisionplus.net/
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
What type of washer does the LG WM2277H take for the cold inlet hookup?
The water supply lines for the LG WM2277H are the same as almost all clothes washers sold in the US, which are standard garden hose threads, and use a standard garden hose washer.
I have a LG washing machine, model WM2277H. Ready to wash clothes, put the machine on but no water is entering the machine. water valve is open, cleaning the filter inside the hot and cold tubing to the...
Kinked inlet hose. Screened hose washer in inlet hose plugged. Frozen water supply pipe(s). No power to washer inlet valve(s). Old inlet hoses with separated layers, blocking water flow under pressure.
Turn off valves, remove from machine end, put in bucket and turn on valves to make sure you have water up to machine. Now work back to find why you are not getting water into machine.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
