I am unable to connect my phone to computer
Try this:
1. Start off with the device unplugged from the PC.
2. From the home screen, tap Settings, Applications, Developer, and enable Debug Mode.
3. Next, go back one stage so that you are at Settings, Applications, and this time go into Manage Applications.
4. On the top row of tabs, select All.
5. Scroll down the list (alphabetical) until you locate MtpApp. Tap on it, and then tap Clear Data.
6. Plug in the device
7. Drag the notification bar down from the top of the screen.
8. Tap on debugging mode to open the developer screen again, and tab debugging mode to dissable it.
9. PC Companion should now connect. If it still takes a minute, let it do so and don't deem this as a failure until you have received the failure message. Remember, new devices can take a while to connect depending on your envionment.
Man, at least I tryed to fix this problem for more than 4 hours, your method is the true method, thank you anyway. God bless you. :)
i dont see any apps named "MtpApp". I see one app only, named "MTP Extention Service" and it's cache is 0.00 KB, so I cannot clear data or anything. Previously I always could connect my Xperia-S with Sony PC Companion, and even with MTP to browse the folders of my cellphone. but after I re-installed windows few days back, I cannot connect it anymore. What to do?
Is this what you're looking for?
http://www.sonymobile.com/global-en/tools/pc-companion/
Good
