Now when I try to download books I get the message "SD error please make sure that your device is not in USB mode." and when I go to settings and tap storage I get the message "unfortunately settings has stopped" Any suggestions on how to fix this problem would be appreciated. thank you
SOURCE: I CAN' T DOWNLOAD WITH
You will most likely need a driver so that your computer can recognize the device. Check the box that your Coby Kyros Tablet PC came in with and grab the Setup CD. It should have the driver inside the setup. If not you can download the driver (which may or may not be) at coby's official site show here
http://www.cobyusa.com/?p=prod&prod_num_id=10498&pcat_id=1013
Hope this helps : )
SOURCE: where can i find free driver software download for
Need
driver and bios updates? Always
get your drivers and specific software from the manufacturer of your
Laptop, Notebook or Desktop. They are usually free of charge. If you were to log on to the
manufacturer's
web
site,
usually one is able to download if available, by model
number,
All
available Driver
downloads
as required.
If the driver is not
available, perhaps your manufacturer does not support the OS you are
installing. This is the best way of ensuring up to
date drivers for your system and they are free of charge! I hope this helps.
SOURCE: i want to up root
z4 root one click root will permanently or temporarily root your tablet. Here are step by step instructions. z4 root is one of the simplest root utilities to use out there. It should be easy. Have fun and good luck http://www.androidtablets.net/forum/coby-tablets/6840-coby-kyros-mid7015-utimate-guide-rooting-android-market-clockworkmod-recovery.html
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It
came time to part with my review unit of the G1 (Thanks T-Mobile!) and
send the phone back to its rightful owner. But what about all the
personal info on the phone? The apps, texts, e-mails, AIMs and all that
jazz? A quick search of AndroidForums.com turned up an easy way of
restoring your G1 to factory settings:
if you power
off your phone and hold the home (shaped like a house) and the end (red
hangup button) for about 20 seconds you get a triangle with an
exclamation point and a picture of the G1.
Now all
you have to do is pop open that pretty QWERTY keyboard and there are
several keyboard shortcuts you can use to accomplish what you want to
do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory
settings. I'm sure the soft reboot could be helpful too, should you run
into problems a troubled application may have caused. We didn't try the
other 2 options so use at your own risk.
By the way, I couldn't
live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile
service plan. I'm still a loyal Verizon customer and will simply have to
keep both plans... but I NEEDED the G1. So basically, you can expect the
application reviews and insight you've gotten at phandroid.com to
cotinue since we've got our very own device now!
[Via Android Forums]
SOURCE: can i download kindle to
You need AppsLib on your tablet (you can download from them), and from there you can search for third party readers (I dont think you can get kindle as its designed for phones). Android tablets dont have access to the android market place therefore tablet manufacters have their own - in this case AppsLib.
