When i plug it in and put the key all the way in, the up and down arrows on the incline work but none of the rest of the buttons work, the display screen always displays 0 and the walker will not move.
SOURCE: golds gym trainer 480 treadmill stays at full
Dear Sir: I will try to help you, you must use some basic tools: screwdriver, Hex, Dvom(DigitalVoltemeter): http://www.youtube.com/watch?v=MIIxoPtvhy8 http://www.youtube.com/watch?v=M7qJrRbdfBc http://www.youtube.com/watch?v=Uzf4az4RRDE http://www.youtube.com/watch?v=9G4MZh8JO2Q This will be fix it. In another machines: You will follow the next: Any board control for elevation motor has 2 LED : DN= Down +UP= UP for Elevation Motor, when you push the button for Down the LED Yellow or Green DN, will be going Down Lit, and Viceversa. The Relais in this case 2 relais, will be operated by 12 VDC, you must Clean The Contact, with Special Solvent . You can buy from Radio Schack. Check the Fuse with Dvom, and Finally after you must check this, and the motor is Not O.k is Faulty. Replace. But check before any Wire loose, before to concluded that the Motor is Bad. If you need further assistance, you can reach me, sincerely God bless you. E.CUADRA MANAGUA, NICARAGUA. C.A.
Dear Sir:
E.CUADRA
