Question about Miele W310 Front Load Washer
My miele novatronic will not power up. the fuse is good and there appears to be no cable damage
I have a Miele Novatronic 310 washing machine. It does not power up. I have checked the fuse and taken the top off the machine all seems to be in good order. I have emptied the unit of any excess water and cleaned the filter. my wife reported a dull clunk sound when she went to turn it on. The drum turns as it should. It seems if a trip has gone inside as the door does not power open and there are no LED lights at all. Any ideas. Kind regards Barrie Fox
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Leak from Novatronic W310
Bit the bullet and stripped out the covers from the unit so as to observe where the leak was coming from. Ran m/c on a basic quick wash (be careful, exposed live electrical terminals!!!) and noticed that water came from the detergent drawer for a second or two.
Stripped out detergent drawer housing and found that the large discharge pipe underneath was very blocked with black/white residue. Presume that this had been dislodged from the walls of the pipework during the house move.Removed residue and reassembled unit & ran, OK.
Saved myself £100 call out. Give Miele their due though, the documentation suggests that if you habitually wash at a low temperature, which we do, you should occasionally run a 95degree wash. My wife was very surprised when I asked her if she did this.
Posted on Apr 23, 2008
Anonymous
SOURCE: miele novatronic w864 washing machine
There will be a small qty of water left after the wash. However if the compartment is full then the syphon tube is probably blocked.
Lift the flap of conditioner compartment, you will see a round 'post' in the middle to the rear of it. Pull this gently off. Give it a thorough clean and also take whole soap draw to sink and rinse. Where you removed the 'post' flush through with hot water. Replace the post (will click into place).
You should now be good to go.
Posted on Sep 21, 2008
Anonymous
SOURCE: washing machine not spinning
I had a similar problem and about a week later it didn't wash at all.
Turned out the water inlet valve (one of the three) was faulty. The rubber seal/seat had a small hole and wouldn't open to allow water into the machine.
I wasn't prepared to pay the $213 for a new one so I went to our local appliance spares place and found one that was similar and used the rubber seal/seat from that to replace it. It was an electrolux single inlet valve part #360313 (from memory). Cost me $37. Could've got it for $22 delivered off ebay but I needed it asap.
Posted on Jun 05, 2010
James Foster
  • 251 Answers
SOURCE: I have a miele novatronic w 1918 model washing
Hey - the inlet solenoid must be faulty - unless you have changed the wash options which is an outsider possibilty.
Posted on Jun 15, 2011
I have a Miele Novatronic washing machine model# 1611 which has a fault showing - Water Inlet Fault. The water supply line from the tap to the machine is clear. What could the fault be caused by?
the actual cold water doleniod its self is probable faulty if tests out ok then take the connectors off the the soleniod select a wash start machine and test for power to the soleniod if no power then faulty computer
Jun 04, 2018 | Miele Washing Machines
Wash motor won't run on any programme. Pumps and fills OK
Could be the motor, could be the control board could be a broken belt ...
Aug 29, 2017 | Miele Washing Machines
Miele W828 Check inlet red light flashing
Just wanted to mention mine was retaining the fabric softener and skiping steps in the cycle and intake red light was flashing too. Once
I cleaned the draw and used a toothbrush to unblock the holes in the ceiling its working again perfectly. Miele Novatronic W 828.
Mar 07, 2013 | Miele Novotronic Premier 500 Front Load...
Washing machine not spinning
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section appliance will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent ( Y - Piece) from drain pump blocked.This requires front panel to be removed.
If the machine detects a fault then an indicator light will flash,(rinse light for motor circuit).
Apr 22, 2010 | Miele Novotronic Premier 500 Front Load...
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Miele novatronic w864 washing machine
Miele novatronic w864 washing machine.This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 28, 2008 | Miele W864 Front Load Washer
Apr 21, 2008 | Miele W310 Front Load Washer
Miele W310 Front Load Washer Logo
90 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Marvin
Marvin
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
