Sportcraft TX 4.9 Model 4041 Walking Belt Logo
Mike Allen Posted on Oct 21, 2012
Treadmill tx4.9 keeps giving me an error code 3
REEBOK GT30 TREADMILL. It has ERROR E2. What does this mean please?
E2 Error usually indicates that the treadmill is overloaded and applies to various models like TR150, TRX1000 and TR 200. To fix this problem, check if your treadmill motor is overheating. Signs of an overheated motor include; grinding noise, motor produces a burning smell and inconsistent operation speeds.
Treadmill repair : r/fixit
Reddit · r/fixit 3 comments · 4 years ago Hi i have a reebok one gt30 treadmill bought in 2016. Recently at ... Start googling error codes and find out what E2 means. Upvote 2
Which part of my broken treadmill should I try replacing? - Reddit
Apr 18, 2020
Urevo 2-in-1 giving e10 error message- did you encounter this ...
Oct 10, 2022
Need help with Sole F63 treadmill error code - Reddit
Nov 21, 2022
More results from www.reddit.com
Reebok jet 300 treadmill e02 error - motor output dc is 11v on ...
All About Circuits https://forum.allaboutcircuits.com > threads > reebok-j...
Jan 9, 2023 - It seems to me to be a problem in the circuit that gives feedback to the processor about the voltage in the motor, error02 and does not arm the ...
Missing: GT30 ‎' Show results with: GT30
Treadmill Support - Reebok Fitness
reebokfitness.info https://www.reebokfitness.info > treadmill-support
View user manuals, assembly guides, instruction books, and technical support videos for all Reebok treadmills, including how to reduce static shock.
How do i fix my vfit treadmill error code showing on display error code 03?
If you wish to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
1helpful
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Pacemaster gold elite giving error code 133. Checked all connections so far and continuity through wire connecting top and bottom boards. No luck
please reset the treadmill, follow this steps and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nordic Track C2200 Error Code 440-17E what might be wrong?
reset the machine, follow this step and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
2answers
E09 code on pro fitness treadmill
My motorized Treadmill is showing error E09 how can l clear the error?
2helpful
Hi, i have a problem with my treadmill (Carllewis) it keep giving me error code no. 2
The error codes generally are a failure of one of the electronic components on the machine. Due to the intricate nature of the repair, we recommend a professional come and take a look at it.
4helpful
2answers
Top Sportcraft Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
