SOURCE: Soyo Flat Screen TV Sound or Volume control is stuck
Hi deborah card,
Lets first make sure your remote is not causing your problem,
Look at the light (led) on the remote, is it lit and pulsing?
If not you are having a problem with the control panel,
Have you recently cleaned your tv with a liquid?
If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it. Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: TV volume goes down with out being touched
may have a sticky button or a shorted transistor switch.
SOURCE: volume goes down to 0 and the menu goes on and off.
A bad connection on the small signal board may be the problem! Have a Tech check this connection, it may be to tight due to the heat shrink tube. Have them peel it back to reduce the strain! Should work then!
SOURCE: Volume control Sceptre X42BV LCD HDTV The
To start the conversation, i would like you to ON the TV and take the remote to a different room. Then observe and see, if there is an issue with the volume. If not, then this is a case of faulty remote. I have seen few times when a faulty remote could send irregular signals and cause to volume to react in an unusual behavior. If the problem remains the same, then this is an internal failure and needs repair. You need to open the TV and check different components. In most cases, it is often faulty main board, however we cannot jump to any conclusion without testing the components. If the remote is not at fault, either you could call a tech or if you have prior experience of working on these sets, have electrical equipment and would be able to carry the repair, revert and i would be able to provide few more details and could possible provide you with a link to buy service manual which would be helpful.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: The volume on my TV
dear user,
ur tv side button are rusty.kindly hit the side buttons with hard thing bt slowly..i hope this will help
