Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and start normal cycle. If this proves to be ineffective, then contact a professional to move forward accurately. Possible causes could be a faulty power cord or house wiring, defective control board, thermal limiter or door switch.
SOURCE: need part break down for frigidaire FEX831CS top
go online to frigidare's web site,or contact sears parts central
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Hello trinileigh19 - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
