Error 55.00.00 DC Controller Error
SOURCE: hp color laserjet printer gives 55.1 error
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
SOURCE: Error 57.04 - how to replace DC Controller
you may have this resolved already or possibly you just decided to purchase a new printer or have it serviced somewhere.. so if someone happens to care:
Remove fuser
remove front top cover by removing stay on leftside and screw on right side slide cover to right and remove
remove rear cover 2 screws
remove top rear cover 3 screws along forward edge use flat blade screw driver to lift sides
remove left side cover 2 screws and 2 clips
remove metal cover 10 screws (3 left 2 top 2 right 2 botom 1 botom right from rear of printer
http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1231025390823+28353475&threadId=1096617
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
