Question about Brother MFC 240C All-In-One InkJet Printer
Won't print in color
  • Brother Master
  • 32,281 Answers
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Posted on Oct 23, 2012
6ya staff
SOURCE:
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
HPS 6500 all-in-one won't print
uh,faulty ink carterige, buy another one & don't forget to remove the clear tape seal..on the carteridge
Feb 09, 2013 | Office Equipment & Supplies
Color won't print - Deskjet F4210
you are having a defective printer head so just got it replace or get another printer
Feb 04, 2013 | HP Deskjet F4210 All-In-One InkJet Printer
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
How to turn off color ink in Epson Stylus R300
There is a place in the printer driver (epson part) that hays checkboxes for "color" and "Black & White". If you are trying to do this becasue you are out of one or more of the color inks, and can't print- you still won't be able to until you replace the empty ink(s), even though you told it black & White
Aug 30, 2012 | Epson Office Equipment & Supplies
Need only black to print from HP Color Laserjet 4700 printer
on the print page just before printing , go to properties and make black the default color
Jun 04, 2017 | Office Equipment & Supplies
Printer won't print in color, no matter what i try.
Did you try setting the color printing in printer properties.
If you have XP;
Open 'Printers and faxes'.
Right-click your printer and select 'Properties'.
Click 'Advanced' tab.
Click 'Printing Defaults' button close to bottom.
Select 'Paper/Quality' tab.
Select 'Color' option.
Click OK until all dialog boxes are closed.
Sep 15, 2011 | Lexmark X3650 Printer
How do I print a color page in black in white so i won't use up the color/
Open 'Printers and Faxes'.
Right-click your printer and select properties.
Click 'Printing Preferences' button (Close to the bottom of the dialogue).
Click 'Paper/Quality' tab from top.
Select 'Black & White'.
Click 'OK'.
If you want to use B&W cartridge for all documents, Click 'Printing Defaults' button from advanced tab and change the same setting.
Sep 04, 2011 | Canon PIXMA MX310 All-In-One Printer
I installed new b&w & color cartridges and the
in your printer try to press on the restart button and hold it for about 8 to 10 seconds. by the way the ink cartridges that you installed are the genuine ink cartridges, if not then its gonna be normal that it won't detect as new.
Jul 11, 2011 | Dell Office Equipment & Supplies
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
200 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
