I have a Lasko wind tower fan less than a year old. The rotation and the light work perfectly , but, the fan doesn't blow any air. Does that mean my fan is trash already?
TOOK OFF THE BACK, USED AN ADD DUSTER IN A CAN TO GET DUST BUILD-UP OUT, PUT THE BACK COVER ON, TURNED ON FAN, MOTOR WORKED BUT THE BLADE DID NOT TURNTOOK OFF THE BACK, USED AN ADD DUSTER IN A CAN TO GET DUST BUILD-UP OUT, PUT THE BACK COVER ON, TURNED ON FAN, MOTOR WORKED BUT THE BLADE DID NOT TURN
AnonymousJul 06, 2008
I also purch. a lasko tower fan & it has same symptoms, fan turns beeps but blade will not spin.Ive tried cleaning all the **** out but did not help
I also have a lasko tower fan & it has same symptoms, fan turns beeps , it rotates left and right,but blade will not spin. Please helpI also have a lasko tower fan & it has same symptoms, fan turns beeps , it rotates left and right,but blade will not spin. Please help
You can't post conmments that contain an email address.
Mine stopped. I cleaned oiled and chaged bushings. it would run for a while and stop. I found if I started it by hand, it ran the other way instesad of pushing air. The motor polaroty somehow runs either way I push it to turn. Go figure?
A tower fan should not be opened at all. (It’s unsafe to do so, and may damage your fan.) Every two to three weeks, simply use the brush attachment of your vacuum cleaner on the tower fan intake grills to remove lint and dirt, or use a can of compressed air to blow off dust from inner fan blades. That’s it! Your clean tower fan is ready to be plugged back in and get back to keeping your home breezy.
It is possible that the main capacitor is faulty and so the coils is not enerrgised to start.
So check winding and check the capacitor for open.
Test capacitor by charging both the pins to mains voltage and shorting the pins to see if charge is retained.If retained the capacitor is good, if not replace.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
I had a similar fan which
quit.I could sometimes get it to start
spinning by banging on it.Finally took
it apart.Lots of small screws, all
small phillips.As I suspected, the
"thrust bearing," which supports the rotating components, had become
"stiff." I thought that it would be a non-friction (ball bearing),
but it is only a bushing, with washers supporting the shaft.With the motor opened up, I greased the
bearing with petroleum jelly, and reassembled everything.It is spinning very quietly now.Final comment - this is probably more work
than the average fix-it person would want to take on, but it is doable.It took about two hours, start to finish.I could do it in less than one hour now that
I know how to do it.
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
I have a Lasko HVB, but this might apply to your fan:
Without taking the thing totally apart, here's an idea you can try: The power cord on some models (like mine) has a "warning" tag. I had the damn thing all apart when I noticed this. (Well, who reads 'em??) Seems like there's a mini-fuse in the PLUG itself that, when it blows, there's nothing you can do about it except send it for repair to a factory authorized yadda yadda yadda. Who's going to do that??
If you plug in and NOTHING HAPPENS, here's what might turn out to be an cheap and easy fix: cut off a few inches of the plug end of the cord and go buy another plug at Ace. Heavy duty might be appropriate: don't think I'd want a lamp plug on this baby. Get one that's easy to install. Bring the cut off piece and they'll help you find exactly what you want.
If you want to open it up, there's a screw behind the Lasko medallion, remove that and you can snap out the grille. You can see where the cord comes in from the back of the blower housing. Test the line voltage. If you're not getting about 120VAC, it's the plug.
If that's not it, IMHO, without some knowledge or a schematic, you're screwed. That'd be me. It wasn't the plug.
