When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Peugeot service centre and get them to enter this code for you.
SOURCE: peugeot 206 keycode for radio showning up error 7
It is showing Error because of wrong codes entered previously.
To reset , leave SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself. It can take up to 24 hours...but normally it is only an hour or two.
If you require the correct code then the radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also confirm the MAKE of CAR it is fitted into.
SOURCE: A Clarion car radio cd player in an 206 Peugeot
the cd mech. is bad. you need to replace the cd mechanism.
SOURCE: i need my peugeot 206 radio code
Your code should be either 3728 or 1728, depending on whether your radio will accept a 1 or 0 as its first digit.
SOURCE: removing radio and get codefor peugeot 206
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard in order to identify it (and if you are lucky, someone may have written the code on the casing ) .
Radio removal instructions can be found here
http://www.fitaudio.com/
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE + model of CAR
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
SOURCE: how to unlock peugeot 206 radio showing 4 error
Leave SWITCHED ON...UNDISTURBED and it will automatically reset itself.
It may take several hours.
Make sure you have the correct code
If you do not have the code then read below
removed from the dashboard (and if you are lucky, someone may have written the
If not then POST A NEW QUESTION
Also quote the MAKE of CAR
Serial Number
Otherwise try your Main Dealer ...........or take it into a
