2001 Acura 3.2TL Logo
Posted on Jan 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to replace battery on 2003 acura TL
2003 Acura TL needs a new battery, would like to know how I replace it. I know some cars with computer systems require a certain way to replace battery like " removing negative terminal first" etc.
Thank you
Laird
  • Anonymous Mar 17, 2014
    MISFIRING DO U KNOW WHAT CODE 1399 IS?
Barry N Melissa Spring
Level 2:
Sergeant:
  • Expert 230 Answers
  • Posted on Feb 11, 2009
Expert
Level 2:
Sergeant:
Answers
230
Questions
Helped
109776
Points
770
Remove negative terminal first!
1helpful
How to change headlight bulb in 2003 Acura 3.2 CL
Nick, To see how headlight bulb is changed, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Replacement How to replace install fix change hid head light ballast...
Headlight Change 1999 2003 Acura TL 1999 Acura TL 3 2L V6
Acura TL Headlight Replacement WITHOUT removing the bumper
Does anyone know about a 1997 acura tl 3.2 that was running fine then would die like out of gas, then start and run fine after holding relay switch wires together?
Acura TL Repair and Service Manual Online For 1995, 1996 ...
? 0:43
www.youtube.com/watch?v=dLJ0G0jxXXs
Nov 20, 2014 - Uploaded by Chris Cruz
Acura TL Repair and Service Manual Online For 1995, 1996,1997, ... All Acura TL submodels including 2.5, 2.5 Premium, 3.2Premium, 3.2, ...
I disconnected battery and antenna for 2003 acura tl but code wont take
on the TL - 5 digit code for the radio; 4 for navi; numbers are typically on a sticker on the side of the glovebox (nearest radio) or rear truck arm (great security acura?). Need to unplug the antenna and then put in the code, reconnect the antenna and your back in business. search the net to learn how to access the back of the radio. typically needed after power is lost to the vehicle, new battery installed, etc.
Mileage for next scheduled maintenance 2003 Acura 3.2 TL
the next scheduled maintenance should be at 50,000 miles and the car should be under warranty still.
id say that when the car hits around 55,000 miles giving it around 10,000 to use the oil to the fullest also change the filters,sparkplugs and wires, and add some kind of gas tank cleaner to keep the car running strong :)
2helpful
2000 acura TL horn blows when replacing the battery
dont you have the alarm key fob? if so that will reset it. just press unlock. If you dont an dits not a OEM Acura alarm you will need to find who makes it and get a new key fob, or have a shop that does alarms to disconnect it.
2003 Acura TL 3.2 61,000 transmission
I doubt they did anymore damage but i`ll bet that the engine was damaged from the training going out such as valve guides and seals and carbon build up on plugs ETC.
3helpful
2answers
INVERTER REPLACE ON A 2003 TL ACURA
where can I purchase the inverter for a 2003 Acura 3.2 cl it is in the headlight
3helpful
2answers
04 acura tl serpentine belt diagram
there should be a belt diagram from a label either on underside of hood or on radiator support. That should help if you can do it yourself.
Top Acura Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you an Acura Expert? Answer questions, earn points and help others
