CAN I HOOKUP 4 8 OHM SPEAKERS TO MY MARANTZ 2252B
SOURCE: Marantz support question
Hi I had my SR7200 in the shop also. The 1st time they said that they couldn't find anything wrong with it. I brought it home and had the same problem. Brought it back and they had it for about 1 month and finally called and said that they talked with Marantz and the DSP needed to be replaced. They said that they would have to send it to Mararntz and it would cost about $150
SOURCE: Marantz SR8500
Check the settings on your dvd player!. It might be set to PCM
instead of HDMI.
SOURCE: No sound out of speakers (Marantz SR5200 receiver)
sounds like you might need to open it up and check the speaker wires that you plug your speakers up to it might be lose or something else like that cause it happened to me before and that was it.
SOURCE: new tv, new marantz sr5004, hdmi cable- no sound
To really help you would require a bit more detail. HDMI is the video part of the signal - the audio part may require additional cables. Also, source material may play a role. I'd start by seeing if you have some audio outputs from whatever your source is and connecting those to the Marantz. Beyond that, I'd need more info to be sure I was giving decent advice.
