Washing machine wont drain
Hello,Do you hear the pump running when it is supposed to? If no and the
machine is still under warranty, take advantage. If you do hear the
pump running, but nothing comes out--lower the drain hose down near the
floor to see if it will gravity drain into a bucket or pan. If it
drains, then the pump isn't moving anything even though it is
turning--it must be replaced. If it doesn't drain freely, then
something is blocking the drain--a pinched hose either to or from the
pump, or maybe a stray sock blocking the outlet from the outer tub.
Thanks
