I'm trying to connect my pc (HDMI output) to my old Toshiba 80h82 (component RGB input) to play Netflix. Does my TV have a digital to analog converter or do I need to buy a converter?
SOURCE: Toshiba 46H84 HDMI Card Replacement
The only thing I could recommend is to return the board and get the right board. open the set and get the part number on the board itself. You cannot modify a set to work things it was not designed for without reprogramming the microprocessor. Good Luck
SOURCE: Black box in center of the screen?
could it possible be a problem with closed caption setting....is this a square or rectangular box how big?
SOURCE: Toshiba 52hm84 DLP-HDMI Component has been compromised?
This is a wild guess, but I believe that you are being **** by the movie industry. The HDMI protocol includes a form of DRM (Digital Rights Management) for high resolution content called: High Bandwidth Digital Content Protection Basically this means that the media (disk or broadcast) instructs the player (in your case the cable box) to insist that any downstream devices (your TV) is industry and DRM compliant. Specifically this evil protection scheme is designed to plug the analog hole and make it impossible for you to record or copy the movie by using an analog output from your TV. This even restricts the size of the TV you can play the movie on, thus preventing pubs and bars from displaying the content on big screen TVs without paying royalties. The message means that the manufacturer of your TV has refused to toe the industry line. 1984 Anyone ? Martin
SOURCE: Have a Toshiba 42hm66 tv. The HDMI port has quit
The best thing to do is to call Toshiba at 1800-631-3811 and see if they could refer a Service Facility to you to check it out. I would guess that that Board that has the HDMI Port on it needs to be replaced but it is not a easy or simple job.
I hope this helps,
Skyassoc
