Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Copier Canon iR3300 error E000003-0000. How can I reset the copier if the monitor shows the error and it is not otherwise operable. I turned the main switch off and on to no avail. Can anybody help? Thanks!
    Master:
  • Canon Master
  • 911 Answers
Hi you need to enter in service mode first
in the control panel press the next secuence:
press adittional function
press 2 and 8 at the same time
press again adittional function
service mode should appear in the screen. if don't repeat the procedure until it does
in service mode press
COPIER, then FUNCTION, then CLEAR
select ERR and press ok
turn off the machine from the main switch for about a minute.
restart the machine and try to make some copies, if problem persist there is a malfunction in the fixing unit. get technical support. i hope this can help you
Posted on May 02, 2017
5 Suggested Answers
eric400
  • 66 Answers
SOURCE: Error E000001-0000
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
Posted on Apr 23, 2009
john archer
  • 186 Answers
SOURCE: I receive an error E000013-0000
Check your toner waste bottle it may be full. Also the tube that transports the wast toner may be clogged. In which case its time to call a tech. John
Posted on Jul 03, 2007
Anonymous
  • 214 Answers
SOURCE: need user's manual for imagerunner ir3300
Here's a link for your manual. Good luck. If this helps you plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
http://ris-systech2.its.yale.edu/ris/driverdownload/CanonIrSeries/Manual/Rui_g.pdf
Posted on Mar 06, 2009
Anonymous
  • 318 Answers
SOURCE: error code E000019-0000
Hi this is only indicating a dirty waste toner bottle neck.
It is easy to solve.
Take a star screwdriver,remove the one screw of the left lower panel.You will find the panel at the left-lower side of the machine,the side were you have to open to remove paper jams on the fixing side of the machine.
After removing that panel,remove the bottle remove the toner inside the bottle clean the NECK of the bottle inside and outside and put the bottle back in it's place.Put the panel back and switch machine on and off.
THIS WORKS ALWAYS
Posted on Mar 10, 2009
mdgm
  • 89 Answers
SOURCE: How to reset factory setting for Canon ir3300 copier?
Could try MMI clear to reset user settings to factory default. In Service Mode go to Copier > Function > Clear > MMI Then press ok.
To get into Service Mode Additional Functions (has * on it) > 2, 8 > Additional Functions.
Posted on Jul 26, 2009
HOW TO CLEAR ERROR CODE E000002-0000 IN CANNON IR3300/2200
http://www.copytechnet.com/forums/canon/24451-canon-ir3300-error-e000002-0000-a.html
Thread Canon IR3300 Error E000002 0000
Quoting:
wilson Technician Join Date Feb 2009 Location PASIR MAS , KELANTAN
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
Jul 02, 2018 | Cannon Office Equipment & Supplies
Ir 3300 copier error code e000732-0001
Canon iR3300 Error Codes Code: E732-0001
Code
E732-0001
Description
A fault is detected by the main controller PCB in the communication between reader controller PCB and the main controller PCB
Causes
The connector has poor connection. The reader controller PCB is faulty.
Remedy
1. Connector, Reader controller PCB Is the connection between the connector J1014 on the main controller PCB and the connector J409 on the reader controller PCB normal? NO: Correct the connection. YES: Replace the reader controller PCB.
Below is the site this came from which lists all the error codes in case another occurs after you resolve this one
Canon iR3300 Error Codes List page 1 from 12
Aug 27, 2016 | Canon Ir 3300 Black & White Copier
Error code E000350-0001 in ir3300
Its the serial number board. Someone swapped the main controller out and didn't change the small serial number pcb with it. That board HAS to be returned to the machine or it will not function. Only way to get a new board is through Canon engineering.
Feb 11, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
My Copier IR3300 of Canon, its display E000002-0000 or E000003-0000, i want to now that why it can show that. plz. help me.
Those are both fuser errors. Have you had thunder storms or other power issues? If so it may only need reset. If not the most likely cause is a failed fixing film assy.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
Nov 22, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How to rectify error code E000002-0000 of canon IR3300
The fuser may need to be replaced. Sometimes that code can be reset in service mode without replacing that part.
Service mode--- Additional functions button, then hold down the 2 & 8 key at the same time, then Additional functions button again gets into the mode. Then select Function, Clear(CLR),Error(ERR) then hit ok and cycle main power. If it resets-great. If not,you need a fuser.
Sep 02, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Code Error in cannon ir3300
Hi Abhishek,
Go To Below official Canon Printer Page For Your problem Error Codes Canon iR3300 Still having Problem Then follow Us For Canon Printer Support
Mar 12, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
ERRCODE 00064-0000
replace the trancefer roller or hvt power supply board
Jun 30, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Error code E000007-0000
I have machine of canon ir3300 this time show this problem in machine E0000007-0000.
Jan 12, 2010 | Canon imageRUNNER 3035 Black and White...
My canon iR3300 is displaying error code E000002-0000. Please help.
My canon iR3300 is displaying error code E000003-0000. Please help
Jul 30, 2008 | Office Equipment & Supplies
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
5,435 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
