Rumor touch I have no signal and yellow signal bars cannot call out or receive calls. phone says I have1x signal strength. I am in the same location that I am always in. The signal bars are white until I try to make a call then the bars turn yellow and there is just dead air. Please help.
SOURCE: LG RUMOR went through washing machine!
well my phone got wash in the washer and dryer but it works all except the sound so you should try the rice thing im doing that n is helping whith the screen it had water on it but know it only has a lil bet so yeah
SOURCE: how to connect to bluetooth (ant) device with lg rumor phone
Not sure if you have paired your bluetooth with your phone yet. Hold your bluetooth button down untell it flashes (usualy blue and red) continuously your phone should then find your bluetooth then it will ask for a code. Usualy the code is 0000. If not make sure your bluetooth is turned on:)
SOURCE: I, have an lg rumore touch... And i accidently
master reset the ph or go to messages- mesages settings- text messages- blocked/unblocked messagess
SOURCE: Can't disable lock feature on LG rumor touch
hi, it is very possible to unlock it permanently or increase the time..all you need to do is to go to setting on your phone...check your phone setting, then try to locate your automatic key guard....you could increase the time or you select off..
