SOURCE: 2004 Dodge Ram 1500 Hemi Sport Quad 4WD
on my 2004 ram 2500, I had to depress the trip odometer button and turn on the Ignition. all lights on instrument panel will illuminate, continue to hold button in and tach/speedomenter will run full up and back down. once this has completed, the obd codes will be shown in the odometer.
Good Luck
SOURCE: dodge ram 1500 the radio and dash lights are not working
did u look at the fuses under the hood there might be one there other than that sounds like you wiring went bad or the part of your switch is bad replace the switch
SOURCE: 2004 Dodge Ram 1500 pickup speedometer and odometer quit
I am having the same problem. I replaced the speed sensor on the rear diff. and the problem went away but when i started it the next day the problem came back. If you figure it out let me know.
SOURCE: 03 Ram 1500 E-Brake light flashing
its possible the switch on the e/brake unit broke, take a flashlight and locate a single/double wire that goes to the e/brake assembly (this is the piece you depress with your left foot) and look to see if the wire is broken or the switch the wire goes to is broken.
