Computers & Internet Logo
Posted on Jan 03, 2009
4800 baud rate communication in vb
I am doing a project using vb 6.0 to communicate a device . currently i am using 9600 baud rate N parity 1 stopbit .while iam using this i able to communicate the device .if i change the baud rate to 4800 i am unable to communicate the deice .
pls help to solve the issue
  • stufftoy Jan 29, 2009
    Have HP laserjet 4p printer. Cannot print from window XP to printer. Need new printer? Situation fixable? How?
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Jan 04, 2009
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
17882
Points
59
You have to change it on both side!
If you are communicating your PC with a serial device, BOTH must have the same speed (serial device: 4800, pc: 4800)
Have you done it?
Most devices DEFAULT settings are 9600 baud rate, N, stopbit1.
But you can change it depending on the device...
I have symbol ls9100 400bc it read barcode but does not display out put
Seems like you need to setup the communications protocol. You need to setup the type of communication that the device you are connected too if serial port then RS232 plus baud rate data bits parity etc.
Can you tell me the communication setup for the xl200GPS MEADE 8 inch telescope. Like the comm Port number along with the other settings. Thank You.
If you mean the LX200GPS from Meade, http://www.meade.com/manuals/505ccs/index.html#tc gives the following settings for the AutoStar RS-232 Serial Com Port:
Baud Rate: 9600
Data Bits: 8
Parity: None
Stop Bit: 1
Flow Control: None
http://www.meade.com/manuals/autostar/apb.html has the pin assignments for the 4-pin and 6-pin adapters that connect to the RS232 cable.
Most versions of Windows from WIn95 on will automatically assign the serial port an unused IRQ port if you add a add-on card to a PCI or PCIe slot. (USB to serial port adapters should be able to do something similar with the above data.)
I hope this helps.
Sep 12, 2013 • Optics
1helpful
I have a Cipherlab scanner 8001, when i connect it to a linux computer, it doesnt download it gives me a Time out error, but when i connect a Cipher scanner 711 to the same COM port it works. Please advice...
OK,you indicated COM1 serial port is working on the a Cipher scanner 711.
Please check the communication setting on the Cipher scanner 711.
The most popular setting are
AUTO BAUD RATE
or
9600 bps 8 bits N for no parity check and 1 for check bit.
Short for as
9600 8 N 1
Check the setting on the Cipher scanner 711 communication speed and make set the Cipherlab scanner 8001 to the same rate.
MAKE SURE YOU RE-BOOT the Cipherlab scanner 8001 before re-try.
Please keep me up to date on the fix via email.
17helpful
2answers
1helpful
I have an Epson TM88II and it only prints question marks. How can I solve this
??? Assuming using serial port ???
Question marks are substituted for bad data.
Normal reason for this is incorrect Baud rate.
Test:
Power on printer while holding feed button.
Current settings including baud rate will be printed.
Press feed a second time to complete the test print.
Set port to setting specified by printout.
e.g.
(at command line)
mode com1:9600,N,8,1
mode port : baud , parity , data bits , stop bits
I hope this helps
How do I restore factory settings to a zebra barcode printer LP-2844-Z
The ^default command has been added to the EPL2 commands, starting in firmware version 4.39. This command will set the printer back to factory settings as long as the printer is in page mode. The command is not supported in line mode at this time. The command is case sensitive.
Syntax: ^default.
You can send the command to the printer via the parallel or serial port.
Parallel:
Open command prompt (DOS prompt) See windows instructions for details.
At the prompt type:
ECHO ^default>LPT1 <enter>
Serial:
Assuming standard communications on the printer of Baud 9600, No parity, 8 bits, 1 stop bit and use of COM 1:
At the prompt type:
Mode Com1:9600,n,8,1 <enter>
ECHO ^default>COM1 <enter>
Need to connect to the console port what are the settings
This all depends on what model of firewall you have.
But the settings are most likly
Baud Rate: 9600
Data: 8 bit
Parity: none
Stop: 1 bit
Flow control: none
You may need to play with the Baud Rate
My system tell me that my serial port is running at 9600 bad. My motherboard is new enough to be running at top speed. What is the problem and is there anything I can do to fix this?
The mother board can be new enough to run at 19200 Baud rate or even more but most of the devices run at a baud rate of 9600. If the baud rate of the motherboard is increased then the communication between the device and the motherboard can become an issue.
If you still want to change the baud rate then the option will be available with the software you get with the device you are using with the serial port.
If I can know the device attached to the serial port then I can help you further.
Kindly Comment.
1helpful
2answers
Grand Canyon Tech
Grand Canyon Tech
