Question about Samsung SGH-E900 Cellular Phone
I have new samsung beat m3510 .jar file dosent work
I have samsung beat m3510. i downloaded much of game of jar file format but when i transferd it to my mobile it showeb unknown. give me some of game which could work.
    New Friend:
I HAVE NEW SAMSUNG M3510-BUT ITS JAR IS NOT WORKING
Posted on Dec 22, 2009
  • Samsung Master
  • 5,638 Answers
How to Recover data from Locked Samsung
Samsung Lock screen removal can be easily removed with the help of Android data recovery Tool. There are various types of Samsung screen lock available such as PIN, Pattern, password & fingerprint which can be cleared without any hassle and no data is loss.
By using this application, you are able to extract and recover data from locked Samsung, and you can easily recover photos, SMS,contacts, music, videos, pin or locked password of Samsung Galaxy S9/S8/S7/S6/S5, Note 9/8/7/6/5/4/3, A9/A8/A7/A6, etc. The recovery process takes you only a few mouse clicks.
LEARN MORE
Posted on Dec 10, 2018
I have samsung u600 i want to software for connecting to comuter uros
Posted on Jan 03, 2009
Anonymous
SOURCE:
How can I get my Samsung M3510 beat unlocking CODE for free?
Mast reset is different from unlocking code..Unlocking code will release the network lock..And master reset , reset your mobile if you forget your security code..
If you want to use your mobile with other network means, you have to unlock it..It can be done through codes..If you need get the code from http://www.prounlocking.com/ .It helps to unlock your Samsung M3510 beat easily.
Apr 20, 2012 | Samsung M3510 Cell Phone
How can i install the java game if it says that my *.jar file was over max size?
Sir!
Go to your phone settings and open up the application settings, then there is a option of max file size or something like that then open that option and change it to max size what ever you want. otherwise use the files which are compatible to your phone.
Thank you
Mar 29, 2012 | Samsung M3510 Cell Phone
Error on installing java games? i try to install a same game with the same phone, but my phone always saying that the download jar are invalid, while the oder phone installed the game correctly? please...
before install games to your phone, make sure the java games (click to go free java games list) is compatible with your mobile phones, know your phone first especially entertainment capability features, including operation system or platform (like symbian, windows mobile, java mobile, flash etc), display screen resolution (like 128x160, 176x208, 176x220, 240x320, 320x240, 352x416 etc), 3D java support etc. (get free java games here) . If you get any sort of error, it's possible the games isn't compatible/or is not designed for your model. You will need to obtain a specific version for your model.
first of all Make sure the game is in a jar format (*.jar file) not a zipped file (*.zip or *.rar), most of games here are .jar format. If it has the zip or rar extension open the file in Winrar/winzip (download winrar) and look at its contents, if it has lots of files like a.class and image files then rename the *.rar (or *.zip) file as *.jar and transfer that to your phone. If in the zipped file it has a jar file and other files, extract just the jar file and transfer it to your phone. some phone models also need .jad format file to install the game, check out this post: Create .Jad file for .jar format Java games and apps, download any of .jad generator tools, create your .jad file and transfer .jar and .jad file to your phone.
When transferring the java games to your phone via usb cable, bluetooth, infrared, memory card (how to transfer photos, ring tones, games to your phone), the games and applications folder may not appear, this is normal. All you have to do is copy the file to the root directory (the main folder) and the phone will put the files into the correct places itself. There is no need to put the game in the others folder as it will just be a waste of time and the game will not work.
open/run the jar file to install the games, then enjoy it.
May 28, 2011 | Samsung GTC3300 Cell Phone
I have problem in installing game on my phone (samsung sgh-e760),i dont know how to install and which format i have to use.
YOUR PHONE IS A JAVA ENABLED PHONE.
IT SUPPORTS .JAR TYPE EXTENSION. IT MEANS IT WILL SUPPORT ONLY THOSE GAME WHOSE NAME ENDS WITH .JAR FOR EXAMPLE ASPHALT.JAR
GO TO WWW.MOBILE9.COM AND DOWNLOAD JAVA SOFTWERE FROM 176 x 220 RESOLUTION CATEGERY. AND INSTALL THEM. USE MOBILES DEFAULT BROWSER TO DOWNLOAD GAME.
INSTALLATION MAY TAKE SOME TIME SO DO'NT PANIC.
Jan 27, 2011 | Samsung SGH-E760 Cellular Phone
I have the .jad/.jar files stored on my memory card and need to install thegames on the phone. how do i go about. I have want to install new games in my new hand set Samsung SGH J800 Mobile phone. So I...
In many cases this trick was helped.
download the .jar file of application. then convert the same file into .jad format. then copy the both file (i.e. .jar and .jad) to the memory card and through cell install the .jad file.
Please let me now was this works on ur phone. This trick works on my cell (i.e. Samsung S3500)
Thnks
Apr 17, 2010 | Samsung Behold Cell Phone
How to install jar file from memory card in samsung m5310 mobile.
if you dont have a pc suite for your phone, you can use a card reader and upload the .jar files in the memory card. insert the card back to your phone and open the .jar file. the system will prompt you to install the application or not.
Aug 23, 2009 | Cell Phones
I cant use my java games.jar format in star s5233.
plzzzzzzz hlp me out. how 2 install it??
when i use 2 transfer jar files from pc to mobile. but when i m trying 2 run dat games. it displays unsupported file types. but Java games are there in phone specifications . plzz post a solutiuon . thank u.
Jul 11, 2009 | Samsung Cell Phones
I am unable to download new games in my Samsung F270 mobile. I downloaded the games in JAD format but it asks for JAR file and when I download games in JAR format it shows as format not supported.
THERE MAY BE SOFTWARE PROBLEM WITH YOUR PHONE.U SHOULD FLASH YOUR PHONE FROM YOUR WARRANTY CENTRE OF MOBILE AND INSATLL ITS SOFTWARE FROM THERE AGAIN.THAT WILL SOLVE YOUR PROBLEM I ALSO HAVE THAT PROBLEM WITH MY SONYERICSSON PHONE. THANKS AND TAKE CARE OF YOURSELF
Apr 28, 2009 | Samsung Cell Phones
Download games
what network are you with ?
May 08, 2008 | Samsung SGH-D820 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
333 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
