Does the company sale a replacement base/ stand
SOURCE: Smell coming from TV
dear,
yes it can be due to new set. the components are new and have just
started working initially that's why they cause smell. if your set is
working fine then leave it like that and use it. if it remains after
few days or increasing than before then u have to notice it in details
otherwise no problem
regards,
SOURCE: need code for ge universal remote for dynex 26
Try these codes for dynex televisions. Dynex Television 1023, 1107, 1122, 1273, 1382, 1383, 1384 If these codes do not work you can call the Dynex customer support at this telephone number 1-800-305-2204. Give them the model number of you television and ask them how to get the code. I hope this information helps you with your problem.
SOURCE: i connected dvd player to dynex 32 inch tv. what
You should be connected to the AV input 1 slot. Change the input on the TV to Input 1
SOURCE: VESA Screws
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too)
Apparently, most mounts include only 5mm and larger screws
SOURCE: I have a Dynex 26
If you are sure the warranty is expired, the cost will be somewhere between $50-150 US. Although it is early for this kind of failure, either the fluorescent back-light or the inverter for it is likely dying.
