Cannot find freeview/digital on our new TV
We currently recieve TV signal through Virgin cable connection but cannot tune digital/freeview channels. Anologue channels are installed ok. When installing channels TV cannot find digital signal?
Problem as above please help
Posted on Sep 10, 2009
    New Friend:
It to do with the analogue being turned off and the digital changeover taking up new channels using different standard. I think that the free part can be updated via the CI clot.
Maurice Leach
Posted on Nov 14, 2012
    Problem Solver:
  • 18 Answers
You can only get the freeview / digital channels through cable by subscribing to a package which includes them. They will then supply the necessary decoder to get the channels. Otherwise you will need a digital aerial and a freeview box if you tv is not dtv ready.
Posted on Jan 03, 2009
6ya staff
SOURCE:
My panasonic DMR-EZ45V will not auto -setup restart the dvb freeview channels it goes through the channel numbers but they do not download only the anologue channels download. it is connected to a...
I have one of these with the same problem. I couldn't find any others with answers but there are people giving answers about the DMR-EX75 showing the same problem due to power supply decoupling capacitor failure.
I just ordered a manual for mine from manualzone.com to try to locate the culprits. - Wish me luck!
Jul 25, 2011 | Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Can you tell me how to tune in a channel when ppreparing to use a freeview box on a onyx sw 1536 ld
Unless you've got an "expensive" Freeview box that modulates its output on to the RF (Aerial) connector then you can't. Most Freeview boxes have 2 aerial connectors - 1 IN from the Aerial itself and 1 OUT to connect to the TV - BUT this is ONLY a PASS-THROUGH connection. This means that the digital Freeview signal which is decoded from the aerial signals is NOT output on the OUT connector and sent down the co-axial cable to your TV. Only the "old" ANALOGUE (not Freeview NON DIGITAL) comes down that co-ax. What you should do is connect the Freeview box to your TV with a SCART cable via the SCART connectors on both. You need to select the AV input on the TV using the remote.
Even if you do have an "expensive" box that does modulate the digital decoded programmes and output these of the RF OUT connector, you should still use a SCART cable as the picture produced will be far better
Hope this helps
Jul 06, 2010 | Televison & Video
No signal on dtv built in can receive anologue
You might need a new indoor atenna. Check Argos for a cheap antenna and plug it in.
If you can not receive any Freeview digital channels you will need to subscribe to Sky or Virgin
Jan 23, 2010 | Televison & Video
I have a sony tv. It only has sound on some chanels. I have checked the cable connection with another tv;it is ok. What should I look for
Hi It sounds like a signal problem, I'm assuming its Freeview channels you are dropping, I have had the same problem on some of my TV's especially since the re-tuning channel 5 fiasco. Have you tried Re-tuning the DVB-tuner from the freeview menu, then settings or set-up or installation, then choosing the First Time Install option as it will wipe all previous channels. If you have a portable you can try it on the same aerial see if you have the same problem with that, then if it is the signal, buy a booster and put that on the RF input, which is what I did with the same problem. I am in a poor signal area and have had to have my aerial raised to get even an average signal.
Dec 06, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TELEVISON MODEL:SAMSUNG LE32B450C4W my gran just recieved this tv today she also use virgin media digital on tuning in the television i noticed i could not find digital tv and that i had to go through...
In short: No.
Virgin Media is received via an external box and there is no way to simply program the tv so that your gran can just press one number.
There is a complicated way, but it would be even more confusing. Some Virgin boxes have an RF (i.e. regular tv aerial) output in addition to the usual Scart output. The RF output can be tuned into a regular terrestrial channel, but reception quality is poor compared to using the Scart. Your gran will have to remember to ensure the tv is set to terrestrial reception and to use the source button and ext when she wants to go back to Virgin. This also will not work when the tv uses it's own inbuilt digital Freeview receiver so it's both confusing and useless after the digital switchover.
Either leave the TV permanently set to ext and tell your gran to only ever use the Virgin remote to change channels, or be patient with her as she takes time to learn how to select between terrestrial, Freeview and Virgin.
It's less than ideal and when I worked for a tv rental company this kind of complication was a major pain for older customers (and younger non tech savvy ones!)
It may also be worth looking for a simplified universal remote control with clear buttons. There is one which has large buttons but the controller is almost the size of a sheet of A4 paper.
Nov 11, 2009 | Televison & Video
How to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Nov 01, 2009 | Televison & Video
Samsung LCD TV LE26R51BDX - No analogue TV or Freeview
Are you sure the TV has a built in tuner? Does your country have digital over air broadcasting like my country or not?
Mar 03, 2017 | Televison & Video
Televison & Video Logo
1,030 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
