The hard drive caddy is out of the notebook. I want to change the 60GB drive in the caddy with a larger drive. How do I get the caddy open. There are no screws on the caddy.
The caddy on all Panasonic Toughbooks are
held together by pressure.
I use several paperclips (unfolded) to wedge
between the side of the caddy and the small holes
which are located around the caddy. There are two
along the right side, one in the front and one in the
back and two along the left side.
I usually start with the far left side and work my way
to the back, then to the far right side, slowly prying
with pressure a few millimeters at a time.
Finally I go to the right front, then the front and
at last to the left front, almost in a circle.
It is a little tricky and may require several attempts,
but the caddy will come apart. Please try to remember
how the cable attaches to you can re-attach after
you change the hard drive.
Good Luck
SOURCE: panasonic toughbook cf-27 cd/rw drive
www.Newegg.com is a great place to purchase this product. Nice laptop BTW...
Armymason
SOURCE: I have a CF-73 toughbook that keeps dropping off network
What frequency is your wireless network? And do you have a cordless phone in the area where your router is? You may have to go into your router settings and select a different channel within its frequency range as some cordless phones will constantly scan the channel bandwidth and knock off your wireless connection.
SOURCE: upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
SOURCE: Please i need xp drivers for my panasonic toughbook cf- 73 PC
since i am not sure about the manufatures for audio,video and wireless....so i'm giving this link...which has drivers for most manufactures..
http://www.kellys-korner-xp.com/xp_device_drivers.htm
