Check its battery for proper charge. In most cases, this might be the reason. Charge it fully for at least 4 hours, and then check. Gopakumar Gopalan Google
First thing I would do is try to program from another keypad (I am assuming you have a 2 or 3 group machine), it is possible that there is a problem with that keypad or flowmeter. If you cannot get into program mode using another keypad.
even thow alt is new it could be bad,,,the fan runs off a temp sender,,if it is bad it will not turn fan on,,,on fan runs off temp sender one run off your a/c or defroster,,if u get a chance to go to auto zone or advance auto they can ck out your charging system for free,,,, hoped it helped,,
I WOULD SUSPECT THAT THERE IS SOMETHING WRONG ON THIS NEW DOOR THAT THE BATTERIES ARE NOT MAKING GOOD CONTACT WITH THE DOOR AND THEREFORE NOT SUPPLYING POWER TO THE CAMERA. IF IT WORKED BEFORE THE DOOR WAS REPLACED, THERE MUST BE SOMETHING AT THAT POINT. I WOULD LOOK THERE FOR PROPER PRESSURE ON THE BATTERY OR BATTERIES.
This is feed back from a component in the computer or one of the external devices.
Try progressively unplugging all peripherals one by one. Came back if nothing reveals it self
