Mitsubishi WD73737 Logo
Anonymous Posted on Oct 29, 2012
Tv turns off by itself with an amber or red flashing light. lamp replaced about 6 months ago.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 29, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
75
Points
Should be a high voltage or power circuit problem,like transistor too hot,or any component short circuit.
  • Anonymous Oct 29, 2012
    I don't know. Have been told the software needs to be updated.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Mar 21, 2007
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Anonymous
  • 1153 Answers
  • Posted on Sep 18, 2007
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Anonymous
  • Posted on Mar 22, 2008
SOURCE: Mitsubishi WD-52525 Failure
Who needs a repair manual when I have you guys!! Last weekend, my 52525 died almost three years to the day. So rather than throw it away or spend hundreds (not to mention the inconvenience) of dealing with a repair shop - I read your posts. So I dismantled the unit (easily with all the great advice), found the swollen caps, ordered replacements from Mouser, installed, reassembled and the set works perfectly. Also cleaned and realigned the mirrors while it was apart. Like a new TV. Cannot thank you guys enough. Not to mention my family thinks I'm a hero!!
Anonymous
  • 72 Answers
  • Posted on Jun 07, 2009
SOURCE: just replaced the lamp on my mitsubishi wd-65732 2
if you used an OEM lamp rather than an original ,it may have gone out. The more expensive original bulbs last longer
Anonymous
  • 84 Answers
  • Posted on Mar 14, 2011
SOURCE: Mitsubishi WD-62525 Red Status Light After Cap Replacement
Mitsubishi V26 error code 41 with solid red status indicator is caused by leakage from capacitors C9A37 and C9A38 (3300mf/16v). The result is a bad fuse F9A02 (15amp pico) which reports error code 41 indicating short protect. The Mits part number is 283P144040 but any PICO 15a fuse will work.
Bill W.
Integrityhomeworx.com
Kdf-e50a11e diagnostic codes
3 blinks is indicating the lamp has burned out. Aftermarket lamps tend to fail quickly. Only use oem replacement lamps for your sony. You can get replacement lamps from www.tvrepairworld.com
2answers
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
2answers
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
2answers
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
2answers
50v710 turns off by itself then on
Have you check the power supply,that's what it seems to me.
4answers
Tv not turning on
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
6 months ago, the colors started messing up and it made this screaming banshee sound. The TV would turn itself off after a minute or so. I read about it and figured it was the color wheel. I bought a...
You need to put in the values for x,y, of red,blue,green & white.
when you get the color wheel, sticker(printed values) was in the same box.
If you have, let me know and I''ll let you know how to put in.
Panny pt-50lc13 steady amber flashing light
Sounds like a defective lamp diever or ballast.Listen for a buzzing sound when you turn the set on. If you do not hear it then most likely you have a bad ballast or lamp driver. Worst case scenerio would be the engine itself.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
