Hi Ftstar.... things have changed since yesterday I am getting 34 in self dia test. Red light is staying on and not blinking.....
AnonymousMar 18, 2014
md73737 the green light flickers then goes to a solid green but have no picture. do have sound.md73737 the green light flickers then goes to a solid green but have no picture. do have sound.
You can't post conmments that contain an email address.
code 34 is lamp abnormality. Have you replaced the lamp? If so was it factory or sub? Also red light on steady indicates cable to dmd problem.code 34 is lamp abnormality. Have you replaced the lamp? If so was it factory or sub? Also red light on steady indicates cable to dmd problem.
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
This is due to failing capacitors in the power supply. Many people have fixed them self repair but it takes some skill. If you cannot do this yourself, contact Mitsubishi. They will help with the repair under an extended warranty. You will have to pay labor.
Is it possible your having poor air movement around the set. If lamp is frequently blowing it sounds like over heating. Sorry your having troubles. That tv offers a fine picture.
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
