Would like to replace it or repair it...any idea about cost?
Replaceent will be the best way to go since most boards are multi level circuit boards. I would check with www.tvcircuitboards.com they should have either the entire board or just the HDMI port depending on which way you choose to go with the repair.
SOURCE: need base for Insignia NS-LCD26A
Parts for Insignia TVs can be ordered by visiting BestBuy.partsearch.com or calling 1-888-237-8289.
SOURCE: the audio went out on my insignia NS-LCD26A. It
It's likely that the TV will require service. You may take the TV to the retailer of purchase to arrange for repairs.
SOURCE: Remote COntro COde for Insignia NS-LCD26A
You can find remote control codes for your TV here. Select your exact model number. If the codes listed don't work, there is a listing of compatible brand codes that you can try.
SOURCE: I'm looking for the remote control code for an
Insignia TVs are basically re-branded major brands made for BestBuy. I would try codes from the following TV brands:
LG
Philips
Magnovox
RCA
Westinghouse
Polaroid
The codes from one of those should work. Also depending on which universal remote you are trying to use, there may be a scan feature on the remote itself that searches all frequencies for the appropriate one for your TV, so I would look into that. Hope that helps and good luck!
