That's what I thought was wrong with mine to I had 1.75 in change and a piece of a wash clothe in the screen. I toke all that out and it still leaked. Took it apart further and found a piece of the weight that is made out of cement broke of and rubbed through the drum. That sounds like junk to me!!!
SOURCE: Frigidaire Affinity Washer beeps & won't spin
The drain filter is clogged. I had the same problem. There is a filter inside the "drain boot" (black) that comes from the drum to the drain pump. Mine was completely clogged with money, lint, etc..
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
SOURCE: Frigidaire Affinity Atf7000e...Does not load up water.
clean your inlet screen...onthejob...take hose off and take screens out of inlet water vavle and clean then replace..onthejob
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
SOURCE: I'm having a problem with my frigidaire front
If water remains in the drum the unit will not go into the final spin. There may be a couple of reasons which I have experienced resulting in your problem. If water remains in the tub the unit will not go into the high speed spin. 1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water. Shake the hose and listen for coins or a small object this unit will pass items through the pump into the hose causing blockage. 2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning. The hose needs to have a loop in it to work correctly. 3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. The pump is about $60.00 and is accessible after removing the front panel under the door. It is easy access from the front and the hose clamps will be the most difficult problem. I have a ratcheting hose clamp tool designed for this type of clamp but channel lock pliers will work.
Hello geraldinerid - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a further diagnosis is recommended to have a professional check the reed switch.
Hi ajdean01 - I see that your tub appears to be leaking. Here are a few troubleshooting tips that may help you get to the root cause:
· First, be sure that your tub is not overloaded. Sometimes when overfilled, water can and will slosh outside of the unit.
· If the tub is not overfilled, check your hoses and other connections. Like most laundry units, there is always some vibration associated with the functionality of the machine. As the appliance is used over time, hoses and other connections can loosen and begin to leak. Be sure to secure any loose connections.
· If the above items did not assist you in resolving the issue, it could be a number of other underlying causes - primarily an electronic pressure sensor, switch, thermistor or the unit's main control board. These parts are commonly replaced by experienced service technicians.
