I have a sciphone i68+. i cant talk to anyone unless i have the earphones plugged in. is there anyway you can talk without having the earphones plugged in?
Ok, here's my theory you used an earphone but it didn't disconnect. To know if this so if you see the earphone icon on your phone then that is the case. This happened to one of my phones. Anyway here is how you can solve this plug in an earphone and shake the plug gently while still plugged in. Take out the earphone. If the icon comes off problem solved if not.... .... Try again. It is usually because of the switch in the earphone jack that switches between headset and handheld mode becoming jammed. :) hope this solution helps
1) Check to be sure that "Hands Free" mode is off. This may be overriding the settings to believe you have bluetooth connected. and/or
2) check to be sure a bluetooth device the phone is paired with is not on and active.
I've found a french site that talk about this issue... of i68 4G Factory Reset. http://ciphone.fr/forum/viewtopic.php?f=104&t=3094&sid=4bd341345b5689b8aa8fe07a7f8ef402
It's a forum page and they talk about FLASHING de memory of the phone with a special USB cable. We have to build the cable and all explanations is there with pics. I hope it helps.
my phone said gprs not subscribed which was not the actual case. i had internet service but it couldnt recognize it. I called service provider( t mobile in my case) and they text me a package that i downloaded and now it works fine
